Coming from a 290 to the 970 i personally found the Image quality to be poor on Nvidia's NVENC x264 encoder compared with AMD's VCE encoder, there is also a slight performance hit with Nvidia and 0 with AMD, Byte rate on AMD's encoder is also much higher, upto 40 or 50 MBytes/s where as Nvidia its 130 MBits/s
I kid you not i'm doing a lot of recording of late and have got a bit tired of the washed-out blurry quality of Nvidia NVENC.
I actually turned on my Intel iGPU, switched off Shadowplay and am now using Quick Sync through MSI After Burner, even that is better than NVENC.
Shadowlay is very convenient, but actually so is MSI AB if you're just recording, its also compatible with AMD's VCE.
