- 26 Sep 2013
- West End, Southampton
The only way multi-GPU will pick up is when consoles start to use dual GPUs, which is likely to never happen....
PS4 PRO is going to be using some sort of dual gpu setup nexus. I read it's going to have some sort of architecture where it can disable the 2nd gpu for the old ps4 games to provide compatibility, but the newer games attempting higher resolution and higher fps will utilise both gpu's for the grunt required
