- 10 May 2004
- Middlesex
I'm looking at possibly getting a Razer Blade. Do you think they'll update with Kaby Lake as soon as it's available or do they have a refresh cycle?
This looks great, be interested to know how you like it once received.
With the Core could this replace my desktop? It looks like I could have the laptop with the Core attached via TB3 and into the Core plug in monitor, keyboard, mouse and external harddrive, and possibly even an external sound card (otherwise would sound be via the laptop's headphone jack). It seems like the Core is effectively a docking station with the added benefit of being able to improve the graphics! Can you use the Core for output to a monitor or do you need to plug into the laptop itself via HDMI or an adaptor?
Anyone know how a i7-7500U Dual-Core Processor will compare to an old Intel Q9550 @4GHz?
Oh yes of course. TB3 bandwidth isn't quite strong enough to pipe the signal back into the laptop. If I want the extra grunt I'll just plug in my 4K tv into the laptop
Think you're getting confused he's talking about the Razer Blade PRO and not the Razer Blade...
The Pro comes with a 1080, what's the point in buying the Core?
Swapping it will void your warranty.
Do we know whether the Core can charge the standard Razer Blade (not the Razer Blade Stealth) ??
I don't believe it voids the warrenty unless the action of swapping the add itself breaks the system. If anyone breaks their system putting in an SSD they kind of deserve it...
Will I void the warranty by opening or upgrading my Razer Blade's components on my own?
Yes, opening the Razer Blade will void your warranty. If there are any issues with your Razer Blade, please contact your local Razer System Support Team by viewing the links the left side of the page.
You can use the core on any Razer machine. You can use it in any TB3 laptop for that matter.
That's not what I asked, I asked whether it can charge the other devices
And not just the stealth (i.e. Provide power)
Also, it looks like the difference between 256gb and 512tb from Razer is about £200. a 1tb m2 is about £250 elsewhere. Would it be better just to buy the 1tb from a third party? Is it easy enough to swap?
I don't know, but why would you want it to? Is this purely to cut back on the number of sockets you use?
Surely one of the benefits that the core provides is the single connection back to the laptop (keyboard, mouse etc are permanently in the core). So you don't need to faff around getting the power supply out of the laptop bag and then hunting under the desk for a socket.
