Man Cave
18 Oct 2002
Cambridge, UK
Hi All,
Hopefully by the end of November this will be mine:
Mwhahahahhahhhaha ;)
11.97m (39'3") x 5.60m (18'4") :D
I'm going to have so much fun!!!
Obviously I'm going to have to go down the projector route, and some pretty big speakers to fill this space, needs some pretty meaty furniture as it's pretty echo tastic at the moment!
It will have to be "band for buck" rather than "money is no object" !
Cheers
HEADRAT
Yeah its the upstair of the barn ;)
Going to get myself a pub sytle pool table and a Mame Cabinet
Heated yes, not really insulated, it would be a shame to cover those beams!
Certainly no signs of damp or anything like that.
Well the ceiling is clad with timber and then there are tiles on top of that, so while I'm sure it's not super insulated I don't think it will be that bad.
Keep us updated. It's going to take a lot of work to noise suppress that room for a projector set up and speakers for home cinema. Get on it. a lot of fun to be had me thinks.
Projector, music system and a bar. Add in table football, pool and ping pong and you're pretty much set!
Bang for buck might be a PA style system considering the size of the room. You'll need a lot of sound deadening and careful thought to get a proper cinema setup.
I don't want to compomise the space just for the cinema setup so I might have to see what works out best.
There is another complelety undeveloped room downstair which is 7.37m (24'2") x 5.40m (17'9") which actually might work better as a dedicated home cinema room, it would be a much easier space to manage.
That would be easier. I would have upstairs for sporting events and a dark room for films.
So actually you need 2 projectors :D
