- 25 Apr 2011
- Crawley/Gatwick
Morning
Recently bought a gtx 1060 and as always hated the stock cooler. Was looking to integrate the gpu into the WC loop. Project mostly based on:
https://forums.overclockers.co.uk/showthread.php?t=18729855
Narrowed it down to the Thermosphere but wasn't sure if holes will align
Had to rework some of the wires and whoala!
Left the VRM sink as is and added some copper sinks for the ram chips
MX-4 used on the block
Fans had to be brought down and also I have used a dremmel to cut the case mesh in between the fan and the rad both top and bottom to improve flow a little
End result
3 cycles on Unigine Valley Extreme HD did not break the 40c mark
End result
