The Elder Scrolls V: Skyrim Remastered - MODS & TWEAKS
Caporegime
8 Sep 2006
On Ocuk
Welcome to the The Elder Scrolls V: Skyrim Remastered - MODS & TWEAKS thread, please note this post will not be given the full treatment as much as the original one was, because that one was done over many years. However any mods/tweaks will be added to the list and lay out adjusted accordingly thanks to you the members :)
- INI TWEAKS -
Gsync Monitors and Fov
Nvidia Control Panel
:Manage 3D Settings
:Program Settings
- Add SkyrimSE.exe
- Preferred Refresh Rate - Select Highest Available
- GSYNC+Vsync or Vsync Fast is ON
- Anistropic Filtering +16
* SINCE LATEST BETA SKYRIM UPDATE UP TO 60 FPS CAP LIMIT IN MSI AFTERBURNER ISN'T NEEDED *
For over 60FPS Use Msi Afterburner limit frame rates to above 60 fps and use possible way of running 120 fps in Skyrim fix - see below ) )
Then in Skyrim.ini
[General]
sLanguage=ENGLISH
sTestFile1=Dawnguard.esm
sTestFile2=HearthFires.esm
sTestFile3=Dragonborn.esm
[Display]
bLockFramerate=0 <- ONLY add this if you want an unlocked frame rate, otherwise it's capped at 60 fps
iVSyncPresentInterval=0 <-- Gsync/Vsync ON in CP :::::: MSI Afterburner frame limited preferred if over 60 fps( needs to be added! )
fDefaultFOV=107 <- Set this to change fov
fDefaultWorldFOV=107
fDefault1stPersonFOV=107.0000
[Archive]
bInvalidateOlderFiles=1
sResourceDataDirsFinal= <-- these two entries are for loose file mods
Skyrimprefs.ini
[Display]
fShadowDistance=10000.0000
iNumFocusShadow=4
fInteriorShadowDistance=3000.0000
ffocusShadowMapDoubleEveryXUnit=450.0000
iShadowMapResolution=4096
fDynamicDOFBlurMultiplier=0.8000
fProjectedUVNormalDetailTilingScale=0.8000
fProjectedUVDiffuseNormalTilingScale=0.2000
bEnableProjecteUVDiffuseNormals=1
bUseTAA=1
iSize H=1440
iSize W=2560 <- Adjust this to your monitor settings
fDefaultWorldFOV=107 <-- Set this to change FOV
fdefaultfov=107
bLockFramerate=0 <- ONLY add this if you want an unlocked frame rate, otherwise it's capped at 60fps
Skyrim SE Nexus Mods & Installer
Always check for MOD updates at least once a week via Nexus Mod Manager
Nexus Mod Manager
Main Mod Site
Gameplay Fixes & Tweaks
General Mods
Animation, AI Changes and Improvements
Animals, Creatures and Monsters
Mesh and Texture Related Overhauls
Gameplay Mods
Weightless Ultimate - Original Flavor - Ful Potions too heavy for you? Use this mod!
Alternate Start - Live Another Life Want to start in a new location as a new life, use this! (Don't install Opening Scene Overhaul SE Mod)
Combat Evolved
Morrowloot Ultimate - Needs a new game (Changes levels and loot to make Skyrim just awesome - Install LAST)
Immersive Patrols SE
Lighting Overhauls
Landscape Textures
Nordic Snow (aka HQ Snow Texture)
SSE Texture Pack - Osmodius
Realistic Water
Real Mountains
Verdant - A Skyrim Grass Plugin
( If using Verdant, you must make these changes by adding or editing inside the ini files )
Skyrim.ini
[Display]
fGlobalContrastBoost=-0.2
[Grass]
bAllowCreateGrass=1
bAllowLoadGrass=0
fGrassMaxStartFadeDistance=35000.0000
fGrassMinStartFadeDistance=0.0000
iMaxGrassTypesPerTexure=15
iMinGrassSize=60
SkyrimPrefs.ini
[Display]
bShadowsOnGrass=0
[Grass]
fGrassStartFadeDistance=35000.0000
fGrassMaxStartFadeDistance=20000.0000
Simply Bigger Trees SE - (formerly SkySight SBT)
Armour Textures
Body Parts/Textures
Weapon Textures
Weather Changes and Effects
Loading Screen Changes
Sounds and Music
Reshade & ENB's
Skyrim SE Re-Engaged ReShade and ENB (Install Instructions must be followed carefully/install last with lighting changes)
http://www.nexusmods.com/skyrimspecialedition/mods/1037/?
This is a great mod, upgrades characters to be on par with the special edition. Isn't pervy like other body/face replacers, it just upgrades the vanilla!
Little taster: Nord presets during character creation, probably the most recognizable faces in the game.
Thx for this thread, just one question, i see in first post the below, does that mean that Skyrim SE aint using Anistropic Filtering 16 by default then ? i just use the in game graphic settings all on max, i dont use nvidia control panel.
- INI TWEAKS -
:Manage 3D Settings
:Program Settings
- Add SkyrimSE.exe
It seemed rather blurry to me for ground textures at a certain distance, then again might need mods :)
Try it and see
This is what I'm struggling with, even with everything maxed out, the draw distance is just awful on the terrain :(
Any advice on increasing it? I can't find a simple solution in the ini files.
