i5 4670k @ 4.4 Ghz - any worthy upgrade ?
Man of Honour
16 Mar 2005
Clevedon , Bristol
Out of touch with current gen.
Currently running :
i5 4670k @ 4.4 Ghz
16gb Dominator Platinum 1866 memory DDR3
GTX 1070
Any upgrade that would be a benefit in gaming ?
Or should i just hold on to my money
Cheers.
Right now, nothing.
When the i7 7700k is available, it'll be mildly better.
If/when games use 6+ cores all the time, then Broadwell-E and Zen would be good upgrades. But for now that's not a concern.
Depends if you are noticing any performance drops in games.
I went from a 4690k to a 5820k and noticed an improvement in some titles but it's a fair amount to lay down for an upgrade.
Currently running :
i5 4670k @ 4.4 Ghz
GTX 1070
Cheers.
Stick mate, any upgrade right now wouldn't be worth the £££.
Cheers for the replies :)
Not much to be gained then for a year or so then.
Might sneak a 2nd 1070 instead if Black Friday is any good :D
well 3 weeks ago i'd say nothing but then BF1 came out and it's made me worry if i5 are going to become an issue..... as it totally batters i5 cpus
What voltage do you need to get 4.4Ghz stable
1.165v
unless you find a dirt cheap 4770k or 4790k I would hold on.
I had the 4690k and never had any plans but through a deal I got my 4770k for my 4690k and not a lot of cash so I went for it.
Just to chime in with my two pence. I have a 3570k @ 4.4GHz and am noticing hitching in BF1. Mostly during screen changes rather than actual game play. This is paired with 16Gb of Ram and a 970 G1.
I'm kind of thinking its the CPU that's the issue.
And there isn't much in it between a 3570k and a 4670k.
