Xbox one Elite or S?
The Elite is old tech, if you want some new tech buy the S. The Elite controller isn't amazing either, but the S pad is supposed to be pretty cool.
I would go for the S because of the features. I also have the Elite console but because of the controller and the SHDD I decided to keep it when I purchased the S.
The S, without a doubt.
If you buy the elite, you're locked in, no HDR, no 4K UHD etc. If you buy the S you can buy the elite controller separately, and add an external drive for more capacity if you need it.
HDR > everything else in consideration.
(The above assumes you have a 4K compatible TV, even if you don't the 'future proofing' of the S makes sense imo).
If you buy the elite, you're locked in. The benefits of the Elite can be bought additionally (such as the controller if that floats your boat).
I would be inclined to agree with this. Unless you *never* plan on buying a 4k TV/hdr /uhd blu rays
I'm confused - isn't the S basically a normal xbox with bluray and hdr support? New tech is kind of missing the point if it's pretty much 97% same hardware.
It's the same old tech just slightly patched and repackaged.
Yeah good point, if you have absolutely no desire to ever buy a 4K TV, or at least in the next few years it complicates the decision.
I'd still get the S personally, the 4K bug will bite at some stage, if it hasn't already :cool:
eugh, went into GAME and they only had the ELITE, almost bought it but decided to hold out for an S. a bit gutted but think I've made the right choice.
bummer, was looking forward to playing xcom 2 tonight.
