Search the bay of e. As a rule the Halfords stuff lasts a long, long time so why not consider preowned?
I'm sure it's in their T&Cs that if you take something back to get it replaced they can ask for proof of purchase so you'd be losing out on the lifetime warranty if they decide to be difficult.
Never have with me, they just go and get me the new item. Even when years ago I took a 13mm socket back that had split. When I got home I found the Halfords Pro one was in my old Draper socket set and they had swapped the knackered Draper socket for a shiny new Halfords pro one.
I have always purchased the individual tools I needed instead of a set so that there are none that never get used.
I've had the same experience like I said it's just one of those things they could suddenly try to enforce at which point you lose the biggest plus point of the Halfords kit.
The first tools I bought were a Halfords 100pc socket set and lifting kit, the ratchet did break and despite not being covered by the warranty they replaced it with no issue.
Other stuff now I tend to get off eBay, Sealey, Draper or Britool stuff seems to be of decent quality. If I need something immediately there is a small toolshop in my town that does mostly Silverline which is fine. Really the only bad tools I've used are ones from the Poundshop![]()
