 - 27 Dec 2014
 - Southampton
that article feels like rubbish. statements like speed up 1080p gaming to 60 fps and 1.5 TFlops performance ... I mean seriously ???
I wouldn't put any stock on it.
No idea what Kaapstad is talking about there.
HBM's advantage is bandwidth, size-on-card and lower power primarily. Three things that will absolutely make an impact. Fiji's 4GB limitation and inclusion on a card that was really only ever great for 1440p at best kind of put it in a position of not being able to show off HBM's capabilities too much. HBM2 plus a far more powerful card(Vega 10/11) should really paint a strong picture. Especially with games really starting to push into the 6GB+ area of vRAM requirements even at 1080p. HBM2-equipped cards should be able to just basically handle that like a fire hose scrubbing off crumbs on a plate.
And of course the board size and power saving benefits that help in terms of form factor and thermal limitations.
Don't forget NVidia already have a HBM2 card out that is identical in specs (Core count) to the Pascal Titan except for the use of GDDR5X and higher clockspeeds on the later.
I don't think cost would be a factor on a Titan card so NVidia must have had other sound reasons for going with GDDR5X on the higher clocking Titan. The HBM2 equipped Tesla cards will not be run at anything like the clockspeeds you can reach with a watercooled Pascal Titan.
And yes I do think latency is more important than huge bandwidth when it comes to gaming cards.
We don't know what the availability of hbm 2 is so its very possible they went with gddr5x which seemed to be in decent availability at the time. Using essentially the same cooler could also be a reason instead of having to design one from the ground up for what might be a much shorter card.
GPUs are planned a very long time in advance, long before it is known what the availability of HBM2 is likely to be exactly.
No I think the decision to avoid HBM2 on a high clocking gaming card was done for other reasons.
I'm well aware they're planned years in advance, bottom line is we don't know the reason, could be price, could be availability, could be they wanted to use hbm 2 on the "pro" cards so they could ratchet the price more on those. They have their reason i suppose.
Apparently,AMD has managed to increase marketshare!!
http://www.mercuryresearch.com/graphics-pr-2016-q4.pdf
Imagine if they actually had Vega launched by now??
You may be right, though I think NVIDIA knew they could 'get away' with only using GDDR5X for Pascal and still easily get the performance crown.
This then enables them to use HBM2 to further encourage people to upgrade to a 1180 (Pascal refresh or Volta).
Pretty sure it's not going to help AMD at all, even if the card is better than a 1080 ( and I don't believe it will be anywhere near that level of performance, I'd be amazed if it's anywhere near 1070 to be honest ).
I'd be amazed if it's anywhere near 1070 to be honest .
 It is obviously going to be faster than a 1070.Why?!It is obviously going to be faster than a 1070.
TBH other then faster then say a 480x we have no idea where Vega will be
