If you think that changing the handlebars is a hassle compared to researching and buying bikes limited by the handlebar length than...
I don't know why it's bothering you more than it does me but I don't care, I've made my choice.
Want a decent bike cleaning kit. Something to foam up and cover the entire bike and rinse off, and something to clean the tougher spot, bugs and grease etc.
Suggestions? Go!
People who were brave enough to ride in this weather... You have my respect!
Bilt hamber foam is the best stuff, not cheap though.
I don't know about foamy stuff but Sdoc100 is the best stuff I've ever used when it comes to the really tough muck.
I normally use muc off spray on the bodywork, then Sdoc around the swingarm/linkages/brakes.
I have a Karcher, can you use these foamers in the shampoo bottle bit?
It's still mild with a touch of frost so not to bad.
We need some old school weather like years back ...![]()
It's not riding it's sailingI am wishing I'd remembered my Nikwax visor proof this morning though as my manual finger wiping just wasn't quite enough.
Its ok at the moment, the wet weather has increased the temp![]()
