Poll: Any coil whine on your 1080 or 1070?
Do you have any coil whine on your 1080 or 1070?
  • Yes
    Votes: 76 32.5%
  • No
    Votes: 158 67.5%
  • Total voters
    234
EVGA FTW 1070 No coil whine at all. Also has no VRM pads and memory pads that dont touch either it seems :p
Running a old corsair TX 850 power supply
PNY 1080 Founders had a bit of whine on an AX760
EVGA 1080 SC has really bad coil whine on a AX760 and G2 650W.
2nd EVGA 1080 has really really bad coil whine on a AX760 and G2 650W.
Old Asus Titan has no coil whine on my AX760 or G2 650W.
Fortunately EVGA classify coil whine as a fault so I'm going to keep trying cards until I get a good one.
1080 Strix arrived today and there is coil whine under load. I will be RMAing it. First card I have owned with coil whine. My 980 Strix was quiet as a mouse in that respect as have been previous AMD cards I have owned.
No coil whine on my evga 1070 sc before i sent it back due to poor vrm cooling.
Now got a zotac amp and no coil whine on this either.
Psu is a 650w evga G2.
Gigabyte g1 1070 here, I had zero coil whine then played some grim fandango last night now all I hear is whine! Grrr
coil whines annoyingly when playing the witcher 3 to the point i dont wanna play it does it in the battlefield 1 menu and other instances.
sent a video to CS was told basically to live with it
Sounds like bad CS.
Didn't they suggest upgrading your power supply ?
Was there a clear warning either on the card's packaging or by the retailer that coil whine is not a fault and if the card is noisy it can't be repaired or replaced ?
Which card and CS?
1080 msi seahawk hybrid and sorry i meant customer services.
more or less got told its not a fault and doesnt affect performance there isnt a lot i can go as for upgrading the power supply i already own a Corsair HX1000i. i cant really be spending more than i already did for that.
None from me on:
KFA2 GTX 1080 HOF and MSI GTX1070 Gaming X
Seasonic Snow Silent 1050W 80 Plus Platinum (GTX1080)
Seasonic X-Series 750W 80 Plus Gold Modular (GTX1070)
IMO coil whine is usually caused by gaming without vsync on & pushing the card too far clockspeed wise & or using an inferior PSU. Over time all PSU's degrade & massive overclocks on CPU+GPU puts additional strain on the entire system causing the PSU to work much harder.
