- 26 Sep 2013
- West End, Southampton
No dx12 option in the menu, that's strange seeing it's on 1.5PTS.
they had to remove it as it wasnt performing well on the majority of systems unfortunately - must have just been thrown in as an afterthought.
Oh right. Anyone else got the brightness slider bug?
Yeah the brightness slider is greyed out Gamble. When I try and move it, it tells me can only adjust in full screen mode, which I'm already in.
Will try to change it in the config file. What brightness to you got for neutral lights? I reckon 40 will be great.
Also, is it better to deconstruct all my 229 gear or sell?
I only run it for PVE content but I keep it about 40-45 with neutral lighting and sweetfx. Very nice imoSurvival looks sick as **** with it but hard to see past the snow and fog lol!
Sell sell sell!
Had 3 Delta errors in the last 2 hours. Strange, as I never had an issue with this game before![]()
I love to be immersed in the world I don't care about dying so 40 setting for me with neutral lights and sweetfx is mazeballs
What's armour cap percentage Gamble?
Just had an underground run on hard, solo with 229 gear and it was easy.
Proficiency cache's are still 229 :/
I went and purchased a few basic sealed cache from BoOP (400000) and my first 256 weapon is the m700 tactical marksman rifle. Its frikkin epic
special gear vendor in the underground has the same sort of stuff but 256, annoyed i got a 229 liberator.
the base of op weaponery dude has the casidy still, the aug a3 para and the first wave m44 256 which i'll purchase once my gearscore can handle their perks
got 25324002 Division credits.
anyone know anything nice in the darkzone?
its been like this on every update so dont worry, they will do a server reset later in the week and will go back to normal
in wt5 it is still 70% CAP overall, but the max achievable in wt5 with native and additional armour rolls is 56.7%
Anything higher will require either a robust chest or sturdy holster.
Did you get the prof cache before getting a gs256 drop in wt5?
Works the same as every other cache, if your GS isnt high enough it wont drop the highest caches but now that you have some hs256 gear, you wont get gs229 again unless you drop down to wt4
DZ vendors listed here as well as the LZ: http://rubenalamina.mx/the-division-weekly-vendor-reset/
