No free service is truly 'free', they are restricted in some way or you have to give something up.
They typically have one or all the following issues:
Ad Supported.
Speed (slow)
Heavily restrictive data limit (ie. 500mb)
They run of Peer to Peer which means other people are using your internet to brows anonymously. (Bad, ie. Hola)
Latency (slow)
If your serious about using a VPN just buy one that fits your needs, you can get full featured services from £40 a year. Tor Guard, PIA, Tunnel Bear to name a few. Just read the small print carefully as to what is and inst allowed on their network.
I've been using tunnel bear (with 500mb cap) to try it out but what I've noticed is that my torrents don't download but I can surf just fine? Is there a reason for this?
I've just renewed with ExpressVPN. Excellent speeds and totally unlimited. Doesn't come cheap though - about £80 for the year.
Thanks. What up and down source do you regularly get?
I use PureVPN. Its like $45 a year.
. For every provider, there seems to X people saying it's great, and the same amount saying it's awful
.I'm getting rubbish download speeds with PureVPN. In the last few hours the most I've managed is 22mb download. I'm on a 200mb connection!
Any ideas why it's so slow?
