*** The Division Thread 2.0 ***
yeah im avoiding cache's, going for the grind instead. Only took a few days to get my 4 piece nomad and 2 piece alpha in 1.4
I loved that build before 1.5, was a bit of a life saver. Now I've had to swap out a few items and I've lost the 15% health on Kill but retained the 100% regen.
getting fed up now. finally get passed the delta errors and now get random hangs in the inventory screen.
just freezes, sound still going, windows doesn't think it's stopped responding or anything.
They could still be working on it. There were comments made about the UG vendor and changes being made.
Not sure how accurate this is but:
How to fix error Delta 20010186 on PC?
Check the system time on the computer. If it is not accurate you will not be allowed in the game.
Method 1
If you are using VPN software, you will need to remove it. Restart the computer and try to log in the game again. In most cases, it helps to solve the error Delta 20010186.
Method 2
Open CMD as ADMIN and enter the following:
4 lines one by one then restart computer:
netsh advfirewall reset
netsh int ip reset
netsh int ipv6 reset
netsh winsock reset
Method 3
Make sure that your firewall is not blocking these ports. These ports must be open for the game to work properly. UDP: 33000 to 33499 TCP: 27015, 51000, 55000 to 55999, 56000 to 56999
Read more: http://techfaqs.net/games/how-to-fix-error-delta-20010186-in-tom-clancys-the-division/
should point out that it's not just that, got surfaces not rendering properly. nps jumping around the place, not registering hits etc etc.
frustrating..
frustrating..
I wasnt sure if it was me or my internet at the time but the loading screens took ages for me, when moving from safe houses it was taking a good 30 - 40 seconds to load and then loading the game in the first place took ages.
when playing the game was jumpy and trying to land hits when its like that wasn't happening
made it hard to try and play the game as NPCs where all over the place
yeah, normally it's a bit of internet lag but checked my end and all seems okay.
can only assume that TD servers are still getting a battering.
I havent had lag and only had one delta when I first logged in but....
I had 7 game crashes last night, texture pop in and a slight flicker when in my stash. I didnt have this on the PTS so I dont know whats wrong.
Im not on the latest nvidia drivers though which have the division listed so i might try that tonight.
Was annoying, as I was in the middle of missions every time.
tried updating my nvidia drivers too :(
damnit! :(
I even tried reducing my gfx settings to low to completely reduce any load and it made it worse lol
Only thing i noticed though is that when divsion updated - it reset my nvidia settings and turned adaptive vsync off so I might...use nvinspector to restore the driver profile.
Only 1 crash for me last night and it happened when Tony joined my group, incredibly slow loading and 1 delta error. Apart from that, all seemed fine.
Oh and I had audio missing, the voice overs :/
I have noticed some texture pop in too, although this seems to be quite common.
The good news is that HBAO+ seems to be working again for me without that weird ghosting graphical effect.
I spent pretty all of yesterday farming the DZ. I managed to get all new kit and weapons. All at 256 now. Running with 3 piece Sentry's and 3 piece Hunter's. Got the new M700 sniper rifle with 118k DMG and G36 with 294,000 DPS. I spent the day getting the loot and tonight I will try it out. I was able to boost my toughness and DPS quite considerably.
Loads and loads of crashes though lol.
:eek:
I want that G36!! Is that once it's modified or base?
Talking of the M700 Carbon - I love it :D
First few shots were crap but then it kicks in and I only have 2 talents enabled.
:eek::eek::eek::eek::eek:
What's it's damage/dps?
m700 damage sits around 110-115k per bullet with 4300 FA - roughly.
It also has less reticule bloom than a hunting m44 carbine and less recoil so is a bit of a beast.
I have a glasscannon sentry/HF build and can 3 tap elites, 1 tap veterans and reds lol!!
M44 family is still highest damage without a doubt - but the low mag size means most people will choose the m700 - although my m700 is interim till i replace my m44 - favourite sniper in the game
I still have an M44 on one of my chars and it is sweet but yer, the low mag doesn't help it and slow reloads per bullet. Misses punish!!!
Here is how my build is looking atm, rolled one of my gear's stam to firearms this time round so toughness won't be quite as good but DPS is much higher:
Also got the new sniper rifle last night although a crappy RNG :p :( :o
Got the new SMG and LMG too, find them a bit meh but then again, they were also crap rolls!!!!!! But they sound nice! :p
Really want to try and get either striker or/and alpha bridge this time.
Here is 2 of my Chars and the girl is WIP and needs better mods added but really looking good so far and working well.
