Hello. So I just removed my battery to giv it a charge with my Carpoint 4 amp charger and I noticed that the 5 amp fuse that goes in the underside of the charger has blown. Could I use a 10 amp or 7.5 amp fuse instead? Thanks
			At work if i find any Plugs with more than 5A i PAT fail them![]()
At my work place they PAT tested all the electric items in my workshop and I had to dump everything that fail straight away or get it fixed before using again (He cut the leads or plugs off everything that failed)..It has a 5A fuse for a reason.
Seems a bit daft considering it's completely dependent on what those plugs are attached to.
A 5A fuse in a kettle/toaster isn't going to get you very far.
Well those things are on a list that need 13A fuses.
