Climb up so you can look at the top of the boiler, you should see a schrader valve (car/bike tyre valve) on the expansion vessel. Poke the pin in the middle to let some pressure out. If air comes out then you might just need to pump it up a bit, if water comes out then it's scrap.
Just had an external vessel fitted to my boiler, it's an old boiler but seems to work ok - and I'm not keen on replacing it for another 12 months or so.
Haha! Yeah, like Ideal would fit an external valve to pump it up... It's internal, right at the back. Requires the whole thing taking apart![]()
I would like an external one, but there's simply nowhere to put it, unless we re-locate the boiler...
