- 12 Jul 2016
- Leicester
I went for the vive in the end too. Can't wait for it to arrive.
It's not really the tangling that's the problem, just the hassle of connecting them up (if you use them for other purposes) and having an additional cable flying about to be aware of. I switched to a set of Turtle Beach Stealth 450s, makes the experience a lot more seamless imo.The headset plugs into a Jack at the back of your head I use mine with a cloud 2 hyper x and I've never gotten tangled in the head set wire as it just rests down your back with the rest of the cables.
Chances are you'll be fine without glasses - just try it out and see how you get on. You can always compare it to the view with your glasses using the stock cover.I do wear glasses as I'm slightly short-sighted (have to wear for driving), but don't wear them when I use the PC, so not sure if I'll need them for the Vive. So would the 18mm vrcovers be a better option
Good to know!I use the 6mm leather type one with glasses and its fine suppose it depends on the size of your glasses though.
