I work for a Ford main dealer in parts and you would have to pay for a new one then return your old one to them so they can then reinburse you when Ford test it and say its faulty. You would also have to fill in a form with all the vehicle details as well. I personally dont see a problem as its a genuine part being used on the engine it was intended for. I have sold parts to customers with highly modified cars and had no problem sending parts back under warranty as its the same principle.
 Sorted.
 Sorted.Block exemption legislation means it is illegal for Ford to insist on their parts being fitted by their dealers....
So to your point what Ford told you is illegal and perhaps you should remind them of the 2002 Block Exemption legislation so they can correct their data...
There's normally wording within a warranty about the item not being used in the way intended and this voiding the warranty. Unfortunately I imagine this will come under that clause.
It's intended to be bolted up to and driven by a Ford engine in order to charge the battery. In what way is the OP not using it as intended?
I'm not sure at which point the dealer told him it must be fitted by them
 Car made it down to Weymouth last weekend with no problems (150 miles each way, pretty much the mileage some do in their Nobles in a year!)
 Car made it down to Weymouth last weekend with no problems (150 miles each way, pretty much the mileage some do in their Nobles in a year!)Block exemption legislation means it is illegal for Ford to insist on their parts being fitted by their dealers. However you have a Noble so I am unclear on the law but I would suspect it's much the same. You bought a Ford part, used it as intended and it failed. To me it's clear cut and should be replaced.
would it cost a lot more if you buy the part directly from Noble? even same part as Ford?
Well, no actually. They sold him a part to fit a mondeo or whatever not for a Noble.
He'd be relying on fords goodwill, of which there seems to be plenty.
keep upSorry, misread it.
