 - 22 Apr 2009
 - North-West
Can anybody name some of the good door companies?
			It should be ok with the door on the right (hinged on the left) if you get it made in 2 frames, joined by a steel structural mullion. Whichever way you have it i'd still go for 2 frames and a steel mullion. It'll make it a lot more sturdy.
If you have the door hinged on the right, would that not then block your light switch?
Looks ace, better get working on everything else at the front so it all looks as good as the door.![]()
Was going to say the same 2.7K front door is lovely but will look a bit out of place for me!
Rockdoor are the ones to go for, had 3 doors from them now and the quality is fantastic, buy the "Ultimate" though, pointless getting the lower tier ones.
