Err. Thanks. Problem is. I have no idea where to find it?
I have no messages in my "Messages" folder other than from OCUK .
Is the Trust thing located somewhere else?
I know what you mean. Spent over £500 in the last 6 months on Lego after a long gap.
In fact, the only thing stopping me at the moment is the fact that I have nowhere to put them once completed.
is the Lepin stuff good then? I have only bought original Lego till now, but some of the kits are quite expensive.
By the same token, have people bought off Aliexpress before?
Thanks.
If it's your first Technics set you can do much better than the bucket wheel. The Arocs truck is considerably cheaper and much better imo.
Then again I don't like the excavator at all so take my opinion with a pinch of salt.
If you want a big display piece, the Crane MK2 fully extended is massive and very impressive.
EDIT: https://shop.lego.com/en-GB/Mobile-Crane-MK-II-42009
It's a retired set, hence the price. It will only go up in value. Mine's on display, properly impressive piece of kit. In fact I'd go so far as to say it's the most impressive technics set I've ever seen.
Have £15 Lego points about to expire....what should I buy.....tempted to get the Tie Fighter to go with my X-wing or get Detective's Office.
If they last till January, the Y Wing is being re-released!!!
