- 1 Mar 2010
I slept till 12 today, if that's any consolation.
If you did that originally you wouldn't be there at all.
Mike you Rectum - i'm here until half 4:30pm. *Shakes fist*![]()
Don't you like to point out the obvious![]()
Had an absolutely amazing day today![]()
Did you sharpen your pencil? Or perhaps you booped a cute cows nose?![]()
Check facebook messenger![]()
He sharpened someone else's pencil.
The logic of work.
I get presented with a reasonably complex problem with no obvious solution and simply get told to "figure it out"
So I spend 2 days figuring out a solution, then another day documenting it. I send the document to my superior to give it a once over before giving it to the rest of IT, and for some reason I decided to copy in the original requester, this is my mistake
- Original requester pipes up (who knows nothing of IT) "looks complex, can't we have a system which just does X"
- Me "it does do just X"
- Him "but this document is 22 pages long, I only want it to do X"
- Me "yes, and that's exactly what it does!"
- Him "why is it so complex?"
- Me "Most IT systems are"
- Him "email isn't, you open Outlook and away you go, can't we make it simpler?"
*sigh*
- Me "Tom, as you know you're trying to get 3 different bits of software across 2 different platforms to talk to each other and synchronise without issues, I originally advised you that the easiest solution would be to buy some laptops which are not running windows XP"
- Him "yeah, but you can make it work"
Facepalm...oh so hard.
There is always one isn't there.
I do like to help.![]()
Ha well jokes on you I'm finishing at 2 tomorrow.![]()
I'm finishing at 7 tomorrow.
Anyhow, pro-tip: next time just send in the executive summary, and see if that's enough. 9/10, it is.
Good luck with the night shift. Watch out for baby Al Pacinos!![]()
