Plans for your car 2017.
ETA but at £5k I'd hope they'd not write it off
Damage appears to be:
Bumper
1x kidney (came out on impact, not hit)
Wing
Undertray
Arch liner
Bonnet repair
Possibly headlight as scuffed and poss a clip bust
Fog light and trim
Front sensors...
I've contacted Europa who looked after me well for a non-fault prang 6 years ago, hopefully have a car to use soon! Car drives (straight and with no warning lights) but bodywork/wing is catching on the tyre so can't really drive it far.
Cooper Tonbridge wells did some good work back then, Chappell did some touching up a few years ago and it's gone down in quality a little IMO. Any decent body shop recommendations around SE London/Kent?
Would like to fit an inter-cooler, Ideally a Safari Systems one (LC80 4.2TD)
I also really need to deal with some bodywork issues on the LC80.
There are some corroded areas that need to be dealt with before they get too bad.
I also have an old E36 compact coupe that needs work (Mainly on suspension issues, rear axle/sub-frame needs re-building in particular)
By the looks of things...
Only filters beyond model are post 2001 (mine is a 2003) and engine +4.0 litres:
Then to lower the engine size requirement to allow 530i's:
There was a high mileage, private sale estate for £3k but had some issues.
That is properly insane money... For the 530i's in particular! Though from the little thumbnail, the black one looks nice. :p
I'd buy it on the basis that it looks good in that tiny image.
I think that 540i's price is inflated of course, but I can't see a 130K mile car being 'worth' half what a 70K mile car is 'worth'.
the reality is that you should be able to replace it with a like-for-like car with the amount they pay back..
540's being rare you need to be asking a decent amount, I'd say 7-8k is the figure rather than 5k which will get you a decent 530i.
Amarok: Nothing
Rexton: Replace tyres, full service, respray wiper arms, new license plate number, fit chip and k&n, upgrade bulbs, swap out stereo with one that has Bluetooth, fit new matts and full clean inside out.
