Just a very quick one, but does anyone have a Fury X which doesn't make a noise from the coils when under load?
Had mine almost a year now and after the initial advice was just to ignore it and it will go away after bedding in it's no different all this time later. I've now got an RMA from OCUK to send it back but was met with the usual "well it's got to be louder than a certain threshold to be classed as faulty" etc etc. So while I'm happy that it probably is I'm just wondering if I'm likely to get a better one back in return if that's possible?
Thanks.
Thanks.
