Chipset drivers
6 Apr 2015
UK
I have just finished with a new build and have installed the following motherboard drivers (Audio, LAN, USB and SATA) but what is chipset driver and do I need it?
The chipset drivers support the motherboard chipset implementation. They may be installed as part of a windows OS if it recognises the board, so no, not strictly required. Generally I only install the Lan drivers to get on the internet and then if windows does not sort the hardware correctly, I will install additional drivers myself.
I have these exclamation mark in Device Manager under Other devices which I'm wondering is it related to chipset driver that I haven't installed?
Iv come across, some software lately called driver easy. It checks your system for drivers and lets you know if you are missing any or have any that are out of date.
I find it very useful and easy way to update drivers and its all free!
Check it out
probably full of ads!
Always install Intel Chipset drivers to make sure its not using the dodgy Windows Update ones.
Check it out
only for ancient hardware when you can't find an official up to date driver...
99.9999999% of the time, just visit the manufacturers website and download the direct latest version. motherboard drivers realistically will only need to be done once.
+1 for this.Then go to motherboard website and download/install from there.
