- 6 Sep 2016
I have the Halfords 200 piece socket set. Could you not split open the plastic case and use the case as drawer tray?
Must.....pull.....plastic.....from.....drawer.....catches.
Haha yes I did start to take them off but they they tore and came off in bits. Going to borrow my wife's hairdryer to help tomorrow!
I like the industrial stuff. It feels so much more solid than the other boxes.
The pro ones are fine. It's the ones with the red drawers that are a bit off.
nah they have ball bearings. The 5 drawer feels better quality than the 7 drawer though
http://www.halfords.com/workshop-to...ds-professional-5-drawer-ball-bearing-cabinet
Just a quick heads up... you can pick up the 200 piece black edition set for £127.50 using promo code WORK15 (needs to be in caps)
This is even cheaper than trade discount.
The code works for other stuff too although some kit is cheaper using trade card.
probably, but the pro are a lot better than the cheap blue and red/red ones. For home user I'd say pro are good choice, black ones for someone who uses tools everyday.
Replaced the 7 drawer Pro in my work van today with a 6 Drawer Industrial, very noticeable difference in quality
Trade card made the purchase quite easy on the wallet too
sometimes they have the two or three units in a special offer, it may have been better to wait for that. I think the 5 and 7 drawer pro was availalbe at £200, prior to my discount
I like mine too.
P.S If you don't like the way the drawers open / lock as standard i.e. having to open the top chest lid first to open the drawers, it's easy to dremel the mechanism off. I did mine a couple of weekends ago, took 10 mins. You lose the ability to lock the drawer but gain the ability to open them without first having to open the top chest.
