Is the 120i just the same again with yet more tuning?
I have a 116i and its slooooooooooooow, you have to rev the **** off it to get it to go anywhere.
Irrelevant, your's isn't the turbocharged 116i, and is a completely different kettle of fish to the proposed 116i.
What with having a young family, I'd probably look to get something bigger than the 1-series/A3/Golf/Focus, and potentially look at the mid-sized estates (A4/3 series/Passat/etc).
You don't however appear to have any desired age/spec/mileage stipulations, so it's hard to suggest specific vehicles.
What has your previous generation 116i got to do with the one he wants to buy?
Edit: as per the last post.
I have a 116i and its slooooooooooooow, you have to rev the **** off it to get it to go anywhere. Also like most BMWs it has a thirst for oil and MPG is low-mid 30s. Handles nice but its soooo under powered its not overly enjoyable to drive. The standard BMW sound system is awful. Small fuel tank becomes irritating after a while, mine came on run flats that are £104ish each, not the quietest and run flats can be a bit slippy in the wet.
I cant recommend.
Tows my little caravan though so they are not all bad.
2-3 years old
5 door
1.6 Ltr+ engine size
Must be able to have a tow bar fixed
~12k miles per year mileage
petrol
manual
~£14k budget
I cant recommend.
My face when I got and drove the new F20 116i 1.6 Twinpower:
no it isn't, no need to exaggerate - they're fast enough for daily commuting and aren't at all bad looking with the M sport trim.
OP - 116i or 118i
My face when I thought I was getting the old E87 116i 1.6 NA as a courtesy car:
