lol 4MBi remember a time when GPU's had 4MB of buffer
That's the thing, if a £190 4GB card gives 95% of the performance of that £250 one, that's a bad value upgrade.
8gb
If you want to CF a pair of 480s a some point then 8gb is a must.
That imo is the only worthwhile use for 8gb on a 480
Unless there's less than thirty quid in it, I'd go 4GB. Maybe the 8GB will be significantly better in the long run. Maybe it won't. It seems unlikely it will have a vastly longer shelf life either way. At most, the 4GB might need the textures turned down a notch vs the 8GB. The card will still wind up outdated around the same time, and will still be worth about the same used two years down the line.
I read an article on the net last year sometime where AMD said it costs them an additional $30 for the extra 4GB VRAM to make 8GB.. that isnt £55 now is it![]()
For 1080p 4gb is still plenty. Most games even at max at 1080p only use around 3gb.
There is a few exceptions like hyper textures in mirrors edge, rise of the tomb raider max textures however I cant even see the difference from ultra in screenshots so seems pointless![]()
eew jagies...
You know... they could have avoided that when making the asset simply by bevelling that edge a little.
I think the graphics card I was using was rubbish.![]()
