Lets see how well you do with this spec me
Caporegime
27 Nov 2005
Guernsey
What car would you recommend to swap my mk3.5 focus ST for ?
Needs these specs
xenon headlights (I guess LED headlights could also be another option)
Around 1800mm wide
Not to long
Fairly decent sized boot
Guess asking for 250hp same as my focus St would be asking to much :p
Am not looking to change my car yet but am keeping an eye out for what my options are ;)
[TW]Fox;30428297 said:
228i M Sport.
The problem there is the rather random 1800mm width stipulation. The 2 series is getting on for 2000mm wide.
I was going to go with S3 but the same problem arises (though it is marginally slimmer than the 2-series).
No budget?
You might want to quantify "decent sized boot" also, as that's subjective!
No set budget at the moment (But let say 30k tops brand new)
228i M Sport.
That looks which good
The problem there is the rather random 1800mm width stipulation. The 2 series is getting on for 2000mm wide..
It listed as 1984mm including the mirrors (Am Trying to find the spec without the mirrors included)
Think my 2010mm focus St spec is not including the mirrors
Would really like something no wider then my old RX8
Which is listed as 1770mm not including mirrors, 1846mm including mirrors
Reason being are roads over here are really narrow
Apart from the hp requirement looks like a Jimny would be perfect.
Probably be the fastest a > b
Problem is
What would be perfect for driving on this tiny island and what most us islanders buy is too very different things :o:o:o...........:D
Bit like many uk mainland guys who need 300+hp to do 70mph..
