Resident Evil 7 Benchmarks
Who knows. Maybe because the Fury-X is on an AIO, and isn't dumping hot air into the system.
It is possible but the difference does seem too high for that.
Either the GTX1070 run was after the Fury card or it could be the Nvidia drivers pushing a greater CPU load as they thread better IIRC.
Or it could be because the cards are using different settings.
This needs to be explained.
My CPU does not show anywhere near that amount of different however many cards I am using.
The most likely explanation given the total load is very similar, is the overlay is reading the package temp. Package temp will read the average core temperature over a polling period.
Like Cat says, the system might have just had longer to warm up. Especially if he's using an AIO cooler, or air cooling.
AMD drivers tend to push less threads and Nvidia drivers do,so we would need to look at CPU usage graphs. If the Nvidia card is pushing more threads,it will be causing the CPU to heat up more.
But again maybe the GTX1070 was run after the Fury X so its simply the effect of the system warming up.
So I guess from now on then we test games with features turned off that benefit one brand the most over the other ??
The only setting I can understand turning off it PhysX or a feature that is tied into the hardware from Nvidia Gameworks. HBAO+ runs a lot better on AMD hardware these days that is an Nvidia in house feature that am sure runs better on Nvidia than AMD so why not switch this off then for example? Leave SSAO.
The Shadow cache feature isn't AMD or Nvidia feature so it should be left alone!
Stupid benchmarking tbh Guru3D lost a lot of respect here
** Update #2: after lots of weird results with graphics card that have less then 4 GB of VRAM we found out that the problematic settings is Shadow cache. If you have an up-to 4 GB graphics card, please turn it off and you'll be playing properly. The charts are now updated to reflect that.
What a load off RUBBISH! 4GB card here and I see massive gains.
At what resolution? Maybe you can show us some frametime data.
Should be a more optimised driver for AMD soon for this game.
The game appears to be running the same or slightly faster than a 1070 on my 390 in the demo when I compare it to some youtube videos. Surely something wierd going on with the Nvidia drivers or is it simply more optimized for AMD?
Nope it's pretty much because AMD cards with 8 gb vram can use Shadow Cache, this super charges them making them punch way above there weight class.
The shadow cache makes some difference mainly in the kitchen with the light shafts but all the other areas run at around 130fps even when it's turned off.
In the kitchen when looking from the doorway at the light shafts, disabling SC drops fps from 105fps to around 85fps. The game runs in the 130's the majority of the time so Guru3D seems to have taken near the minimum fps for his final 390X result.
Overclock3D ran the "high" settings also, btw.
*Rattling of pitch forks being grabbed*
...Not again.
:D
Just uncapped my frames, and tested with the Cache off/on, i do get higher frames with it on (120+ mainly), but when running along, i get quick pauses, every so often, and when looking/spinning around, i get a slight stuttering at first, but then once ive done a complete look/spin, the stuttering stops, goes buttery.
With the cache off, i get lower frames (112+ mainly), but no quick pauses when running, or stutters when looking/spinning around, its just buttery all the time.
Yep, paging to disk will do that, ruins the experience. Nobody wants to play like that...
Shadow Cache is extremely memory intensive. I'm seeing as much as 10GB requested by the GPU at 1080p on my TX. It's a luxury that's not required, and I think reviewers are wise to turn it off.
It will cache how much its allowed.. Because you have 16GB its allowed to cache that much doesn't mean on my system it will use 10GB. Its away of boosting performance and it should be left enabled!
That's not how these things work, don't pretend you understand how stack overflow works based on what you've read from other users. The hitching experienced is enough to tell you there is an issue with cards with less than 4GB, which is where this argument started. Also Titan XP has 12GB.
