I5 6400 core voltage?
13 Feb 2003
My win 10 system is randomly freezing, requiring hard resets.
I've checked the memory and no errors. The voltage is fine at 1.200v.
I noticed the CPU core voltage is 0.944v (no overclocking) and wondering if that's a bit low?
31 Dec 2008
Is that under load.? If so then yes it is too low.
6 Oct 2007
North West
Freezing and no bsod usually points to something other than low cpu voltage. What speed is the ram at, check vccio and system agent voltage, too high or low can cause instability.
OP
13 Feb 2003
It's a new mobo/cpu/ram. Rest is the same. The mobo is msi z170a sli plus. bios is a bit... funky. Will have to search around for voltages.
Couldn't find a 3.3v setting. There was a 5v and 12v. They are showing 5.0 and 12.2 in bios.
3.3v is showing as 3.344 - 3.360 in aida.
28 Jul 2016
A voltage under 1V is very normal when idling, part of the normal power saving features.
Are all the cables from the PSU plugged in snugly?
OP
13 Feb 2003
I've got a crucial ssd, sandisk ssd and some western digital drives - a black and a red I think.
crucial_CT240m500ssd1
ssd plus 480gb
WDC WD20EFRX-68EUZN0
WDC WD5001AALS-00L3B2
