- 5 Feb 2009
turn your htpc into a plex server then purchase one of the cheap now tv boxes, you know the ones that come with a free entertainment pass, or a second hand one. will stream fine to your tv in your bedroom. so long as its 1080. also bear in mind if you buy a new smart tv for your bedroom it will more than liekley already have a plex app, so will not infact cost you anything.
Well, that sounds a great cheap option. A couple of questions:
1. If I turn the HTPC into a Plex server, will I still be able to use Kodi as the front-end? I assume so, but not 100% sure.
2. Would I be able to wake and sleep the HTPC from the bedroom this way?
If both of these questions are answered in the affirmative then that sounds potentially the ideal solution!
