Can anyone kindly recommend an AMD 460 or Nvidia 1050 GPU that have a low or 0dBA fan mode when idle or dealing with basic windows tasks? Most of the GPUs I have seen state the fan % when not under load is above 30%.
The EVGA card (going back info from their forums) does not have 0dBA mode. When not under load the min fan speed is 45%.
You can pick up the Windforce version for about £5 more, should be super quiet when fans do kick in due to designZotac GTX 1050 is 100% silent even from a few inches away: https://www.overclockers.co.uk/zota...ddr5-pci-express-graphics-card-gx-10b-zt.htmlNone are all that quiet really. Only way to make a quiet one is remove the stock fans and mounts, then attach a couple of 120mm fans to it perminently set to about 90%. Which is what I did with my 480![]()
Your wrong mine is still silent under load after playing games for hours @ 1920x1080 you have to check gpu-z to make sure the fan is even running!And under load it will still sound like a hoover.
