 - 22 Jan 2014
Where's the 'Your posts' and 'Your threads' links? I can't find the ones I've previously posted in.
			maybe it's me but i'm more drawn to a brighter colour / white instead of gray
It's been fixed. You need to update the style again
I don't know if it's the dark style, or the update, but...
Nope, I just press the install button.I've changed a lot of settings/colours so don't want to revert - which section fixes the edit box, do you know?
sectionFooter {I've changed a lot of settings/colours so don't want to revert - which section fixes the edit box, do you know?
||forums.overclockers.co.uk/styles/default/xenforo/vbSmilies/used/header.jpeg$image
forums.overclockers.co.uk###Offer
	Is this all your fault?!Getting there now on stylish, much better
Oh come on Gibbo, you'd hardly say it looks bad or give it any negatives. In actual fact many of the DONS/Staff haven't, funnily enough
In terms of positives from myself - I really like the multi-quote saving option, the speed and the notifications. But the design theme is awful, just like the main website... Can you give the members a choice of themes they might like?
All the greats are back!
You are being my hero today. Since it's Valentines Day I could kiss yousectionFooter {
display: none;
Remove that from the code.
Database seems to have been snapshot'd a while back. Likely to return to normal shortlyHmm there seems to be a password issue.
I changed my password about a week ago and have been using it prior to the forum update (which I like) however my new password it doesn't accept but it likes my old one!
