Just appeared on Reddit 5 mins ago..
Those are good scores.... my 4690K @ 4.6Ghz
Single threaded i score 20% higher with 35% higher clock, so the IPC on that RyZen is 15% higher.
The cheapest 2x4GB DDR4-2400 kit costs three times what the cheapest 2x4GB DDR3-1600 kit used too lol.Yup, nand prices just keeping going up with no end in sight yet.
There's barely any premium on fast DDR4 at the moment. The cheapest 16GB 2133MHz kit I can find is around £87, whereas you can get a 3000MHz kit for a fiver more. I paid £75 for a 16GB 3200MHz kit last May though, so prices seem to be really high right now.
There's not really any "bother" in "overclocking" your RAM. You go into the UEFI, toggle XMP on and forget about it, so long as you have a half-decent motherboard. I don't see why anybody wouldn't do it when the faster sticks cost no more and have been validated at their XMP speed. It's free performance, and Skylake at least really enjoys faster memory even for gaming purposes, with significant performance gains to be had up to a certain point (around 3000MHz in most cases, though some games such as Fallout 4 just scale up and up). I guess we'll see how Ryzen reacts to having more bandwidth to play with.It doesn't change the fact that the vast majority of Skylake and Ryzen based systems won't be shipping with overclocked memory out of the box,but at the maximum official supported memory spec. Even the few people I know who have built recent Haswell and Skylake systems,have not overclocked them and just ran the RAM at auto settings. I never bothered overclocking RAM either. I am more worried about longterm stability than trying to overtax the memory controller.
The fact of the matter is the kits running at clockspeeds will start to add a premium anyway,so all this talk of how one CPU might run certain RAM faster is not relevant to probably like the vast majority of people actually using these systems.
Even when the Athlon XP had it's genitals firmly lodged in the Pentium IV's throat market share was still in Intel's favour, because a lot of consumers will simply always buy Intel, as a result Dell/HP/etc know this and are more likely to spec Intel even if it raises their prices and lowers their performance.
As for whether "most" people will do it or whether crappy pre-builts will ship with it, that isn't really something I care enough to even speculate about. It doesn't change the fact that the process is simple and the benefits clear.
With the rysen cpu-z 1.78 leak it's not clear of the turbo speed during the st and mt test,
The baseclock is identified as 3.450 ghz but we need to see a prinout of per core speeds.
Still snifing at 1900 st is pretty good if it's at 3.7ghz for st. My I5 3570k at 3.8ghz st would get 1650.
If the ryzen can get into the 2100's around 4.0ghz-4.2ghz then i'll be impressed.
Things are different now Intel have dominated since 2005. If AMD performance is true & not marketing fluff then for the price its a massive game changer Dell\HP etc etc will go with cost as long as the platform is reliable its going to cause Intel massive issues they have been caught sleeping due to their overly greedy tick-tock policy & no AMD competition until now.Even when the Athlon XP had it's genitals firmly lodged in the Pentium IV's throat market share was still in Intel's favour, because a lot of consumers will simply always buy Intel, as a result Dell/HP/etc know this and are more likely to spec Intel even if it raises their prices and lowers their performance.
IMO AMD are behind some of these leaks, or they are with AMD's blessing, its part of marketing and mindshare.
Ryzen CPU is only the first salvo - its more about getting the core done properly. If AMD does well against even £1000 Intel CPUs,it really lifts their status for the second salvo,the Ryzen APUs.
The Ryzen APU will be another kettle of fish - outside the eDRAM parts,AMD still has the edge using DDR3 and much lower IPC cores in any games. Imagine a Ryzen APU which is 4C/8T and with a Polaris or Vega based IGP??
Combine that with the fact Ryzen is an SOC,so that means they can use relatively cheap motherboards,it has potential to be something HP/Dell will want to use,even in a laptop.
How much are we looking at for the 6c12t xfr model btw?
