NoNameNoNumber;30496278 said:
Mine are the older ones (pre CRD, just Zeta) so aren't anodised fancy red... But yeah it would seem they should move nice and freely like your first one... I'll try and get a little lube into mine then and see if they free off.
I was going to try and get away without using the adjustable RCA but I think in reality I know it's going to need it, really not a fan of these morons running -4º or something just to get their wheels to fit! Function over form.
I've got the same ones - Zeta Pro (formerly known as the Meister R Europa)
Oh yeah, and my back hurts and my neck aches.
I spent 4 hours fitting the coilovers today and I must say, the bits that I *thought* would give me hassle, gave me none. And the bits I thought would give me none, gave me all the hassle. I fitted the front and rear O/S coilovers this afternoon and on the front one - the collars for preloading the spring were nice and free, but the collar for locking the ride height was tight as hell, then the shock body was seized solid so I couldn't adjust the ride height. I must have spent about an hour trying everything I could to get the shock body to turn, but it wasn't having it.
I ended up fitting it as it came from the guy I bought them from and luckily the ride height is *about* right, but ideally I want to take it up by 5-10mm as it just looks a tiny bit too low.
The rear one was the opposite in that I couldn't get the spring collar to move at all, but the ride height collar/body was free and turning nicely. *sigh*
I have soaked the passenger side coilovers in Shock and Unlock so that I hopefully don't run into the same issues. I've set the preload already on them, but the front ride height collar/shock body is seized solid like the other side. Hopefully the shock and unlock does it stuff overnight and I'll be able to fit them tomorrow, but we'll see.
Top tip - make sure EVERYTHING is free before you start.
Good advice on the 5w/40, mine was burning a bit of oil but since going to a slightly thicker oil it's reduced it's consumption massively. Although maybe I should've gone back to 30wt for the winter. Hey hoo
I use the 5w40 over the 30 oil because on track, the oil temps will get too high for a 30 weight oil and it'll just start burning through it/shearing the oil. I use about 300ml each track day, which is about right.
NoNameNoNumber;30496841 said:
Stripped the Meisters down this afternoon Gaygle, too impatient to wait for my friend to pop over. All the dampers are good and I managed to free all of the aluminium nuts off. Gave all of the threads a damn good brushing and lubing up, coated everything with
Loctite synthetic grease and started reassembling. The rears are very straight forward. 14mm spanner to undo the damping adjuster knob then a 5mm allen key and 14mm ratchet spanner to undo the top nut and release the spring/top mount. Gave the rod a good wiggle and cleaned and greased then fitted the new boots.
The fronts are slightly more involved, same procedure though but the top mount houses a 6304 ZZ bearing, both of which were toast. I'll replace with 6304 2RS though as I reckon the rs will be better suited than the z... other than that all plain sailing.
I got the top mount/rose joints all cleaned out... Repeated squirting with WD followed by fingering in a load of grease... They're more like the first one in your video now... Maybe a bit stiffer but I've left them soaking in WD. So I guess they should move nice and smoothly, 1 of mine is pitted though so I ought to look at replacements in the future.
Ahh good stuff. Did you free everything off alright? How did you know that the front bearings were toast?
Now I want to get my springs at least sand blasted... maybe powder coated, any ideas what sort of price that'd be? SB then Hammerite might be a better option... I ought to ring around
Yeah, i'd do that too if I could be bothered
Mine have only really got a bit of surface rust and the paint has come off a bit. Not too bothered really.
NoNameNoNumber;30497373 said:
I would rather mine was a facelift. Panoramic roof would be nice too.
Slightly more power as standard. Teflon coated charger vanes, better ecu that handles mods better and a few extra tweeks with no real downsides.
Charger pulley
Exhaust
Airbox mod
Remap
Coilovers
R56 front brakes and you're onto a fast little car. Plenty of change from 4k too if you find a good base.
Mine is on 99kmiles now and although I have done a decent amount of work to it I don't think its been a bad little car. (Clutch, timing chain, wheel bearings, bushes etc)
I think the one I got was a bit of a rarity. It is a facelift with the panaramic roof, climate control, steering buttons, heated seats and LSD.
I would definitely recommend getting a facelift if you can.
