I like the case but thought, would i regret using it
its USB2 sockets.Thanks, I don't think I could manage thatYou could probably re-wire it for USB 3 if you wanted to!!
the new MB would have a good few USB3s but they are at the back.I like the case but thought, would i regret using it
its USB2 sockets.
Forgot to say, I might get a liquid CPU cooler.
https://www.overclockers.co.uk/cors...iquid-cpu-cooler-cw-9060026-ww-hs-036-cs.html
Maybe the case is to old to mount a liquid CPU cooler? I don't know, never fitted a liquid cooler before.
Thanks.
I thought myself the Noctua was a great cooler but I'm far from an expert. Just reading the forums I thought liquid cooling was best for a 1700 or 1800x.
Sure, I was looking of a new build PC for 4K video editing and was told to get a 6900K but I wouldn't like to spend that kind of money on a chip, even if I could afford it so as you know the 1700 or1800x looked good.
The 1700 would be a lot faster than my current 2700k.
The usb3 hub is a good idea, I would need one with a longish cable then. I use the front USBs often to copy files from my cards to the hard drives.
... it's only a relatively small bump for an extra £100 though.
If I'm encoding a 2 hour file I could wait the extra 5 or 10 mins and that extra £100 would go towards the Ram or something
I converted an old Coolermaster atcs case a while back, similar design by the looks of it. I used a USB.3 front panel jobbie which gave me 4 usb.3 connectors on the front in one of the old cdrom bays. I also modified the whole case to take 120mm fans and ended up installing a corsair H55 exhausting at the rear. So I reckon its doable but it'll take a bit of work "IF" the LianLi case dimensions are similar to my old case. I've got some pics in the "project logs" forum section if you're interested.![]()
