- 22 Jul 2008
- Stonehaven, Scotland
New graphics card (and Haribo)
What do you keep in there ?New Degu mansion............the angle doesn't do it justice, it's freaking gigantic.
Do you have a link as to where you can get one from for £16 please?
This is the streaming via gaming PC to lounge yea?
Where did you buy it from for £16
Yes. Not tried it yet though.
I bought it from a high street retailer. Them and OCUK have recently teamed up so guess they aren't classed as a competitor. Four letters so pretty easy to guess either way. I believe the sale has ended now so might be back to full price.
Bought for a quid on wish.com mainly because i loved the idea behind it!
Just an egg timer but rather than measure the time, it just changes from red to white at the temperature an egg cooks so you know exactly what state the inside of the egg is at without timing it!
So works whether no matter what temperature the water is when the eggs go in.
New Degu mansion
Well an egg cooks when it reaches a certain temperature. This turns white at that same temperature and the resin it is made from I assume has the same conductivity as the egg, so i imagine it is as accurate as you can get as long as the eggs are not massively larger.
And assuming your timer and the eggs start at the same temperature...................
Sat on the fance for a while but took the plunge the over day, 256GB Mi Mix from Ireland. Was expecting it to be massive but it's actually not bad at all, feels the same as my LG V20 if not slightly wider.
