SOME RYZEN 7 1700 OVERCLOCKING!
Poor to be honest, manufacturers caught out by demand and are about 1-2 weeks behind CPU production. :(
Are you able to let the first day pre-order people know what to expect on MBs? Specifically the X370 boards (ASUS Crosshair and Gigabyte Aorus)?
i take it mobo's will be rising in price then if there is a shortage? i have already started saving to get the carbon n 1700 with the nighthawk ram is reason i am asking but if prices are gonna do the same as the memory and ssd's then i'll spend the money on something else.
Probably missed with all this excitement do we know if ryzen is soldered or pasted between chip and ihs?
Looking at the reviews so far of which there are many, there is almost certainly something dodgy about some of the game benches, some of the reviewers seem to have issue with cpu temps but that was likely a fault with their setup and not Ryzen itself.
120mm AIO, 1.55v is max safe voltage anything higher invalidates warranty.
Temps were fine, its a very low power CPU! :)
Surprised AMD are allowing voltages that high given what Toms wrote in their review: http://www.tomshardware.com/reviews/amd-ryzen-7-1800x-cpu,4951-4.html
TomsHardware said:
We prefer overclocking from the motherboard firmware, though. Using simple multiplier and voltage adjustments, we achieved a Prime95-stable 4 GHz clock rate at 1.425V using Asus' Crosshair V Hero (that was with load-line calibration set to Auto). The highest temperature we saw was 82°C during our stress test.
Of course, if you're using a cooling solution less capable than our Corsair H100i v2 at its maximum fan/pump settings, overheating could become a problem. AMD predicts that most customers should see somewhere between 3.9 and 4.1 GHz across all cores, and suggests you stick with a 1.35V ceiling if you want your chip to last. Although core voltages in excess of 1.45V are considered sustainable, they'll have a more pronounced effect on longevity.
Thanks Gibbo for doing this for us, this is exactly the kind of bench I wanted to see done it looks like getting a 1700 is the best option. I'm waiting to see how Ryzen pans out maybe I'll be better off waiting for Zen+ with a better IMC?
Others are reporting issues of getting the memory over 2666MHz. Is this motherboard specific?
I'm not an expert but from what I've read it does appear to be down to the motherboard slightly, but mostly I think the IMC is weak? Hoping it just needs some newer BIOS' to come out to give more functionality. Information atm is rather sketchy at best... Not many motherboards support 3200mhz memory, only the top ends appear too, hopefully Gigabyte can release a board under £200 that will do it.
@ Gibbo
4.0 on all cores is realistic for most users with 1700 and decent air/aio, 3000-3200 ram on a decent board then?
