Can't believe no one has mentioned doing them in a microwave!...
Crack each egg into ramekins or small low dish. When water is just before boiling point, lower the ramekin in at an angle to allow a bit of water in and hold it for a few seconds. Then tip it out - the white will have hardened a bit keeping shape. But main thing is fresh eggs.
Quite likely. While an acid will react with the alkali albumen i doubt the amount of vinegar people add to the pan of water would have any real impact without adding a lot of taste.i struggle to believe vinegar does anything other than change taste, compared to the heat of the water I would bet its a myth, like salting a steak just before cooking drys it out, compared to a several hundred degree pan, it does nothing.
You're not the only professional chef on here.Right. As OCUK's only professional chef. I will chime in.
