***The Vapers Lounge*** 3.0
Gee was talking about making a guide this weekend so watch out for that :)
It's coming don't you worry lads. Had a bit of a busy weekend but it's on my to-do list, hold tight!
So what is the good chargers these days? My trusty old Nitecore i2 has stopped charging right, the first channel almost always thinks the battery is full and the 2nd under charges. The batteries are less than a year old and test okay on the multimeter. I know the OPUS BT-C3100 is meant to be good but can't find anywhere in the UK with stick. Do I buy another nitecore?
Fasttech is your best option mate. Ecolux did have it in stock previously but it's disappeared.
Anyone using the Troll RTA find it to be a juice guzzler?
4 to 4.5ml juice only gives me something like 60 odd hits.
the Smok baby beast & the Aspire Cleito gave me much better economy.
I vape mid to high 40W
Guzzles juice = wicking well.
Also when you think its running empty, tip it on its side, that bottom well compartment hides heaps of juice! Its not too bad on juice for me, fill maybe 2-3 times in a 10 hour working day, the Tornado 150 I have to refill 6+ times in that duration, literally every break and twice at lunch :p
I was thinking of buying a Nitecore i2. They look good and are reasonably priced. Now I just need to buy two extra batteries to make sure I get enough usage out of my unit. The charge thankfully seems to last a reasonable length of time.
When i had the juggernaut coils in my Troll, running at 100w, i went through 20ml of juice in an 8 hour work day alone, today i have two claptons in it and running at 45w, its like going from petrol to diesel LOL
Get the Opus linked above. Much better charger.
It's listed as authentic and for the UK, it will be 100% the same as what you'd get from a UK based store...
The only other thing I can recommend from personal use is the efest luc blu 6, does something like 2x2A, 4x1A or 6x0.5A, used for over a year now, no issues I can report so far, gets used every day.
Anyone tried strawberry chews from jackamoo? Tempted but found their flavours a bit bland in the past vs rejoiced.
if they started to do banana nut bread I'm all over it. Best ADV I've had to date along with big mamas milk.
@Gee Waiting patiently for your guide :D
Happen to know how to make banana nut bread? Since your in Nottingham and I'm in Birmingham maybe you wouldn't mind knocking me up 200ml of the stuff :D
Hello everyone,
Ive red these forums for a while now but only just signed up to post, i need a little bit of help im using a naturevape pro (best flavor so far have tried nautilus mini and the nautilus x and they were horrible in my opinion) MTL setup at about 8 watts with 6mg juice, currently using jackamoo juice that i found here so thanks for that, i find the taste of the jackamoo juices nice but there a little weak on the flavor side for me my favs are the red mist and black mist. I guess i like the fruity flavors most but they still arnt strong enough flavors for me can anyone recommend a cheapish alternative to jackamoo or would you reccomend i make my own? if so where should i get my concentrate as i said i would like strong flavors, im also very lazy so i dot think i would put the effort into making my own mixes lol
maybe someone here has had the same problems as me
any help would be great thanks
Hello everyone,
I'm in the same boat as regards to DIY i think its the way to go but from what i hear you may struggle to get qtys with the new tpd rules someone here will know more so if your going that route get the large order in now.
On the other hand i recommended rejoiced over jackamoo but again 10ml bottles only which isn't a biggue if your running at that 8w mine is 25w and a 10ml lasts a day at best.
Give them a go i prefer them over jackamoo
been diying for 2 yrs .. best way forward for those with hungry attys after tpd .. have 3 ltrs of nic in the freezer so good for 3-4 yrs .. get mine from everything liquid ..
prob getting another before tpd .. takes alittle getting used to but once your there your fine .. just mix in 10ml batches till you find your taste sweet spot then mix a ltr at a time .. lol
TFA Banana Nut Bread - 5%
FA Banana - 2%
FA Jamaican Rum - 1%
FA Butterscotch - 0.5%
Hey guys, I was off vaping for a year and have come back to it. I bought a bunch of FA and Capella concentrates and sweeteners in December 2015, about a dozen or 15 bottles. Looking at the FA concentrates, it says best by April 2017 and the batches were made 2015. How long do you think I could carry on using them? It's a shame really because I barely used much of any.
Tonight I've put together a very simple monkey jizz type juice. I'll see how it goes and I'll stick it in the TFV4, which frankly is the only thing I like using as it never spits, it's very smooth and hardly ever leaks. Guzzler though! Meanwhile, I've got the rest of the TFV4 soaking in steradent in the ultrasonic.
