- 14 Jan 2013
- Horsham
I'm sure this has been covered before but I'd like to know what mouse OCUK's regard as the best for FPS right now such as CSGO, BF1 etc.
Pretty much anything with a 3366 / 3360-derived, plus the Deathadder Chroma.
As for 'the best', it depends about you preferences. I know Roccat is making a 3360 mouse, there's also the G502, the G403 wired (I have) or wireless, G900, but also the Nixeus Revel, DreamMachine DM1 Pro S. The Deathadder still holds its own.
Then you have the 3310-based mice, like Zowies, Steelseries, Roccats, ect...
Do you think I'd notice much difference if I upgraded my G5 to one of the above mentioned mice?
I'm currently playing Battlefield 1 and wondering whether to change.
To be honest, not likely, unless you have actual issues with your G5 (sensor doing weird stuff, double clicks, broken scroll wheel ...). Some faults are fixable (buttons, cable, maybe a scroll wheel replacement).
The closest for a G5 replacement (MX518 / G400 shape), I guess the G402 or G502? Both top tier mice. Probably seen in the pro circuit as well. I personally prefer simpler mice (why I went for the G403). G403 is basically in the same ballpark, even more minimalist. The shape is slightly different. Some have reported issues with the scroll wheels, mine is OK, if a bit loose.
Deathadders are comparable. Some complaints about the durability, and sometimes the shape (hump in the middle).
Thanks for that, I've gone for a G403 as it seems to be a similar size and I definitely prefer the look compared to G402/502.
Hope I notice more accuracy with the sensor!
Agreed here with the G403 wireless and G900. Both have a PMW3366 sensor.the G403 wired (I have) or wireless, G900
