***The Vapers Lounge*** 3.0
So I have decided I want the Troll V2 now... I cant wait for it to come from China so gonna cancel if I can get it over here cheap enough delivered
Any ideas or links?
So going to look ahead and order the items i need
I'm starting off with pre mixed nic 70/30 @3mg 1ltr £25
Is that correct or do i need all 3 items firstly?
Ive used the pre mix and bought all 3 individually, just be aware the premix will go under 3mg when used with flavourings and the vg/pg ratio will change, this wasn't something i thought about when using it. But for ease of use its ideal.
Just using VG and a PG based Nic now.
Buy 72mg nic from dark Star, Pg based and learn to work with that, £25 will get you enough nic at 72mg to last over a year at 3mg mix.
Gee's guide will be up soon, trust me, mixing is easy!! Especially by weight which @Gee will explain in his guide.
Want to buy another RTA, but one with juice control so that I can re wick or rebuild without losing my juice.
I've been researching a few including the Batchelor from Ehpro and the UD Simba, but the one I like the look of is the OBS Crius in black with glass drip tip. I've also checked out the Griffin that riptrippers loves, 3.5ml tank, so Griffin 22 I think like this one? https://www.ukecigstore.com/geekvape-griffin-rta.html
But I'm not keen on those widebore tips and the Griffin has them. I know I can change it but the Crius comes with a glass one so would save me buying one and I always fancied a glass drip tip. It's also the right width, looks the same as the drip tip on my TFV4.
Any opinions guys on those or anything else? I don't mind building dual coils but prefer to build single coils and I don't vape high wattages anyway, only around 25 to 35w. I don't suppose I can do that on these? From one review, the posts on the Crius are 1.5m and probably won't take 24 gauge wire. The Griffin has 2mm so maybe that does. I believe the Crius and Griffin are pretty leak proof? Are they thirsty like my TFV4?
Still questioning if the Troll is the way to go, I want a good mixture of cloud and flavour and if someone can point me where to look would be much appreciated!
If it's the troll v2 rda then I can wholeheartedly recommend it.
It's got a huge deck to build on, I've got a pair Chinese alien coils in it..think they are 3mm but they fit quite easily into the troll.
Flavour and cloud is spot on, I vape mine at about 100watts as the Chinese could take awhile to heat up but once it gets going, boy does it taste nice and loads of clouds.
I got mine from FT as it was much cheaper than buying it here. I also bought the troll rta which I'm still waiting for. Hopefully get it by next week.
I have 2 crius's and cant fault them. Both are stainless though as my experience with black tanks is that the paint chips and flakes.
I think I use 25g wire dual coils, 2.5 I.d.
Perfect, reordered it with the faster UK epacket shipping so it doesnt take ages to come! Ordered juggernaut as that is what I was recommended by a guy that builds these insane coils in a shop I was in, and so thought id give them a try, heard they are a battery drainer and a half, may need to invest in spare batteries and a proper charger for them...
Can anyone recommend a SubOhm tank (not rebuildable*) that can cope with chain-vaping 80VG juice and not burn the wick to hell?
Cleito can't.
Baby Beast can't.
Triton can't.
I'm running out of money and options....
*I know how people say these are the ultimate in everything, but I already have RBAs, RDAs and RDTAs and rewicking something is not an option in this particular case.
Cleito can't.
Baby Beast can't.
Triton can't.
have you tried prodding the cotton before using them to loosen them up a bit so it isn't as compact? (something sharp and narrow)
Why not just get a lower VG juice?
I did. The companies will either not be producing 10mls for the UK market, or will be charging so much it's ridiculous.
Those that are staying and that I actually like are all 75-80VG. Seems very few do 60VGs any more.
It's even harder with 50VG juices for my MTL tanks.
Yep. To no avail.
Which companies do you speak of? You could always add some extra PG to thin it down. Or you know, perhaps move to DIY and mix whatever ratio you want...
