The Pascal GTX 1080 Ti Owners Thread
Ahhh that is neat. Mine all get to 2063 mhz but none seem to do higher then that. What is your memory clock's like out of curiosity. Not played with memory that much, but all are doing at least 12 GHz which is neat. Was thinking maby there was not going to be much overhead over 11 Ghz.
Ive not touched the memory yet . Im hoping to find a bit of time over the next few days to have a play around.
Would any one of you lovely owners do me a favor, please? I'm curious to know what fps you get for Witcher 3 at 3440x1440.
After a quick 10 min play/ride @ 3440x1440p, and after 4 wolves attacking me at same time. Settings: graphics ultra with NVidia hairworks on max and post processing set high never went below 57 - mostly stuck at 60 (any way to unlock 60 fps cap?) with minute fluctuations, not really in the mood to get back into it to test it properly, forgotten how to play it well.
Why is it required to redeem the code.?
The redeem code I was emailed was redeemable at Geforce experience, tne you choose which game and it links to uplay / gets you to log in. As certain models get the game I wonder if they actually are sellable if Geforce experience doesnt see a valid card? Ghost Recon 44.8GB
The codes are sellable, but need to make clear that they have a card a 10 series card really. Sold 2 of my 3 codes for a tidy profit and the buyers confirmed code worked fine no issue.
Just fired mine up for a quick test before waterblock goes on... R6 siege, same settings as my 980ti on 1500mhz 90-100fps - pegged at 144fps
Pretty impressed considering thats before any faffing about with fan speeds or overclocking
Turned up the settings and it started throttling to heat at 83C so set the fan to 60% and it was no more obnoxious than my strix and kept 1836mhz solid.
New Ghost Recon game is gorgeous!
How likely is it to be able to order a reference card this week and receive it this week?
I'm gonna buy now and waterblock it in the summer I think.
Alright, well thanks for taking a quick look :) My 980 Ti gets around 60 fps at high settings with hairworks off, so it sounds like a good upgrade for me. On my first play through of witcher 3 ATM and just a little addicted to it...
anymore confirmations that the afterburner tweak works for voltage control on the 1080ti ? Afterburner works for me but no voltage slider. EVGA 1080ti FE (obv.)
I have tried the tweak but no dice.
Instructions to ammend the oem2 file have been have been revised by Hilbert (guru3d) and I can confirm that voltage control is now working in Afterburner.
