I fear for the 5 range of ryzen.
Depends where you are moving from and what you use it for. Rysen really need to be overclocked, unless you just go for top end 1800x. There are still plenty of small problems relating to memory and motherboard, which I'm sure you are aware by now. Be prepared to spend lots of time tweaking and tuning and problem solving, flashing between different BIOS ver. etc. I have the Gigabyte gaming 3 which is relatively problem free, but still not without its quirks.
If you are not bothered with any of this then the i7 7700k is a much more mature platform. Easy oc to 5Ghz and you have the best CPU for games.
Or if you can afford to wait, give it a few months until all the major boards have had several BIOS updates then see what's what![]()
So odd that the R7 has so much left in the tank and yet its frame rates lag behind an i7?
if you have a look on youtube there are a few vidsHave any of you come across any 3440x1440 benchies on your digital travels? I'm thinking of making the switch to ultrawide.....
In one game, just for clarity. Also how much does that faster RAM cost compared to the slower RAM? Last time I looked there wasn't much difference between 3000 MHz and 2666 MHz RAM, but I never looked at 2133 MHz.http://www.guru3d.com/news-story/am...-to-improve-ryzen-1080p-game-performance.html
A 7% fps increase just from faster memory.
R5 1600 will be the best buy. Same UK price as the i7-920 back in the day!Video from digital foundry actually suggest 1600X has the same (<5% difference) gaming performance as the 1800X.
At $259 that might be the best Ryzen chip.
I know you do have your 1700 already so you have more experience than I do, however, I am pretty sure there was a video showing r7 1700 review/benchmarks where it played games perfectly fine on stock. I am fairly sure it can handle all games on stock just fine. Yes, the OC gives you few more FPS but if it doesn't make difference in your gaming setup (ie. 80 vs 95fps on 60hz monitor) then why bother wasting electricity.
I think the "need to be overclocked" is extremely subjective. Just because it's slower than 4.5ghz i7700k it doesn't mean that it's "slow".
even just running 3.5/3.6 at stock volt is going to help things immensely, again my own opinion of course.Video from digital foundry actually suggest 1600X has the same (<5% difference) gaming performance as the 1800X.
+1 I just watched the video and it's this bit.
I will say that this reminds me of Intel CPU performance in games a few years back. The best performers were the quad-core z97 i7s and the x99 i7s with more cores didn't really improve on gaming performance. It may be what we see here with Ryzen. Except it's hexa-core i5 equivalents vs octa-core i7 equivalents.
And to be completely fair, the cheaper CPUs are the most important ones since more people actually buy and use those ones. It doesn't matter as much what the £500 Ryzen does in gaming, that CPU has more of a focus on other tasks. People shouldn't have to spend £500 on a Gaming CPU, I know it always used to be that folks were recommended the top i5 Intel CPUs for gaming as opposed to the i7s, which were more for CPU-reliant tasks like streaming, video encoding, etc. Most folks bought <£200 i5s for gaming PCs and I bet we'll see similar here for Ryzen.
I can't wait for the Ryzen 5 lineup to release and be benchmarked, comparing to both the Ryzen 7 CPUs and Intel i5 CPUs in gaming. Or depending on pricing, even compared to Intel i3, since those now cost as much as the i5 used to. If it's only a few percent under Ryzen 7 for Gaming, then there we go, Ryzen 5 would end up being the bang-for-buck best choice AMD CPU for just gaming.
But that's only a possibility, we won't know for sure how Ryzen 5 fares until it releases and sees the benchmarks. While I have no intention of upgrading from my overclocked i7-4790k anytime soon, the Ryzen 5 lineup is the part of the stack I'm most interested in seeing. Mainly because I know a few folks who would be interested in buying CPUs at that price-point (i.e. more people would buy Ryzen 5 than ryzen 7) and it would be nice if they got a good selection from both Intel and AMD CPUs.
