The Pascal GTX 1080 Ti Owners Thread
Pic for the users rig section, USB header cable is fugly but hey ho.
I'll probably sort better cooling out in the future, i'm never off watercooling for long.
Wonder if you guys can help me I sold the code I got free with my 1080ti but the guy I sold it to is saying it doesn't work is there a way to fine out if he's trying it on?
I've emailed them, sure it'll get sorted.
First try on GTA V @ 3440x1440 and it's like a different game compared to the 1070.
I found it still looked good with the 1070 near enough max'd, problem is when you add scripts and ENB shaders ETC, that's when the 1070 starts to really struggle @ 3400x1440
Do you think the 1080ti will handle it (60+ fps) max'd out while using multiple scripts with a demanding ENB/Veffects profile loaded??
Thanks
Very unlikely it would have already been redeemed, if it said invalid I might believe it.
Probably sold it on to someone else and is trying to make a quick 20 quid, I'm a cynical twod though :D
I've checked the code and it says it's been redeemed so I think the guy trying it on so what would you advise?
I'm sure I've had this before. If you contact Nvidia ask them if they can give you the time it was redeemed. If they can you can match it being used after you sold it.
Other than that I'd contact Nvidia and ask if they can replace the code and tell the buyer you're doing this.
The guy has a 1070 and doesn't own either game he has sent me a photo saying the code is invalid, has anyone sold a code successfully.
I sold mine and have not been told it didn't work so i'm guessing it did or i would have heard about it.
Remember the person has to have a qualifying card to use it, what card does the guy have?.
I think it has to be a 1070/1080/1080 Ti.
