Just some constructive criticism,
1. You need more audio sources, especially a mic somewhere on the vehicle to capture the engine/exhaust a bit better, from the roadside there is more tyre noise than is ideal
2. I'd grade the video to give it more of a film like look
3. Work on your cuts, they are quite jarring at times which makes it look cheap.
4. Definitely need more 'performance' shown from a performance car.
M3 + empty wet car park ooooooooh this should be fun
NOPE!
You didn't convey the speed and power. Static pan shots are too timid.
The styling was good though.
