- 1 Dec 2009
- Teesside
Sounds like you need a grab wagon to me, will work out cheaper than a skip generally and a lot less labour if the earth is all in one location.
Decided to get another 8 yard skip in the end with a drop door.
A grab truck would cost MORE, even afer paying for skip permit, I guess owing to the fact they can carry more than the skip.
The two trees are also being removed as I need to get rid of the shed and if I moved it now, the tree would just fall down
£215 to have them removed and "recycled".
Does that seem about right? Seems OK to me.
I was quoted £660 to have someone returf for me so will be doing that job myself
Hire a rotovator, flatten it all out, lay an inch of topsoil ontop and lay turf? Sound like a plan?
@darael The Mortgage company have the deeds which show the boundary markings so I need to chase them up to get a copy.
My thinking right now is get a chain saw and have at it. Keeping in line with the wall
If the hedge falls over, he can sue me, literally![]()
See his thread here: https://forums.overclockers.co.uk/threads/hedge.18770864/
@Madwelsh Thank you again.
Very useful information. You seem to have understood the situation very well
The problem is, as you have figured out, it is a mature hedge. I do not have "leaves"... All I have is mammoth branches and mahogany trunks
What you say makes perfect sense.
if you see the "overhead" pic a few posts up (above the one with the bicycles) you can see it has been trimmed back more since then.
At the bottom, it kind of "bows out", if that makes sense?
Tip:
With this new forum software, if you mention someone using the @ symbol, they get a notification about it
So need to reply to other threads
@Madwelsh - like so.
nah.. you misunderstood me, I'm with too many flourishes on the post with !!!!! etc, you prob think I'm a complete loon lol.. I have tried a bit and failed a bit over the years, just learnt through hard experience, chop the top down 6-7 inches, leave it same height 2 inches before next doors side, stick the manure on work it in, chicken manure pellets work them in, water once a week, and a decent soak, not a show and go!!! Like I said, privet is a monster, it's kept under control by no nutrient and no watering, give it both, on a well established plant, it's going to go boom.. I won't be surprised that it rapidly starts making new shoots on the big bare bits.. leave them grow til about 20cm long, then cut by a third, they soon bush out. If privet has food and water and light, there is no end to it, if the temp is up, keep close eye on it!!@Madwelsh Apologies, i think you misunderstood me. I agree with everything you said in your original post.
I was just pointing out how it is now and the other picture was not "now", if that makes sense![]()
