- 25 Aug 2014
The acrylic are stock parts I painted. The Alu I machined myself.Beautiful custom blocks. Perks of the job!
Very crisp. I thought coloured acrylic had been used - wouldn't have guessed you'd painted them!The acrylic are stock parts I painted. The Alu I machined myself.
Looks cool, like the fan covers. The standoffs make them look a bit more snazzy
Never seen that before, what's the purpose of the risers? Or whatever are they? This is really something, amazing stuff!
And they are done.
Yum!
Now to get on with the S Frame itself.
The paint is LUMO yellow with a black based marble with silver overlay. 2k clear to finish.
Very pleased with how they came out!
Yeah looks great but I can't bring myself to use 2k paint. Think I'd instantly knacker my lungs. 1k is bad enough with reasonable extraction and normal paint respirator!
Im glad you mentioned this.
I dont use 2k paint at all unless its a clearcoat. 2k paint is toxic as it gets,the components of the hardener are bloody terrible and I do not recommend spraying this in an urban area with neighbours. I spray outside in a full Tyvek suit with a 3m 7500 something mask with the full on NBC filters,even then I should be using filtered airfed masks. Unless you have the right safety gear and an understanding of the consequences,dont spray 2K. I use 2K clear because it dries fast and hard and I can put much heavier coats on so im spraying for less time.
I PM'd you on FB regarding the painting of the Trident Z bars. Do you have any guide for this?
Thanks
