- 9 May 2006
- Nottingham
Hi all I have the spec in my signature and I did the quick method of hitting 4.6ghz in the bios by clicking cpu upgrade and 4.6 ghz. It set the cpu v core quite high I thought as it would hit 1.366 volts under load and my Temps were a little high.
I've gradually been lowering the cpu v core and its now at 1.260v. This is the only thing I have changed and I'm still at 4.6ghz with much better temperatures and it all seems stable. Is it OK to keep lowering the cpu v core until I get crashes/instability to make the temperature as low as possible?
Thanks
Thanks
